Online: HD17, speedzter
removal of Speedo Glass & Bezel
  • daccadan
    daccadan
    Gooday all--simple question--does anyone know how to remove the bezel on the speedo of big twins(06 WideGlide). i need to clean the inside surface of the glass. if tried twisting the bezel and undoing the allen bolts that hold the dash to the tank but to no luck----I dont want to force or break anything-------- please help its annoying the piss out of me.
    Dan
    I always thought they just pulled off (or pop off using a flat head screw driver to push the bezel up), but I have NFI where I heard that, since I've never done it myself. Maybe someone else will be more helpful :)
    i use Advance Insturment Repairs in Carrington st Revesby   VDO specialist,  good work there
  • TheBigT
    TheBigT
    Mine is the same Dan, only 6 months old and moisture already inside. The original 2010 FXDWG was unreadable in the mornings, and even the new speedo/tacho combo has gone the same.
  • Neo Dutch
    Neo Dutch
    The bezel is swaged on.
  • daccadan
    daccadan
    Bugger--no easy solution--I may have to take the dash off and remove the dash and speedo all for a small job of cleaning the glass. I may have to clean it with one of those anti-misting cleaner you can get from SuperCheap------unbelievable that Harley haven't fixed this issue even with the newer models
