Online: Humbug, speedzter
transmission dipstick and freedom performance exhausts
  • 2000dyna
    2000dyna
    hey guys
    i have fitted freedom performance amendments to my 2000 dyna and just realised when about to commence a service that getting to the tramission dipstick to refill it that it wont be possible to do without removing the rear pipe . Is this the go with these pipes or is it possible to do without removing the pipe?
  • Retroman
    The exhausts fit several model years of Dynas
    Over the different model years the transmission filler /dipstick has moved
    On my mate's 2003 Dyna with V&H Big Shot staggered we had to cut down an Allen key
    The type with a 90 degree bend , left just a 1 cm stub of the " short bit "
    Bit of a pain still,1/4 of a turn at a time kinda thing , but way less pain than taking the rear pipe off every service
  • 2000dyna
    2000dyna
    Thanks mate thought that would have to be the case . Bit of a pain ! Read somewhere ypu can get transmission dipsticks the same as the engine dipsticks?
  • Retroman
    Yes I have seen tranny dipsticks with a knurled knob instead of an allen recess.
    Also with a hex head that stands proud for an open ended spanner to access
  • 2000dyna
    2000dyna
    yer sweet just found one up my way for 37 bucks think it will be a wise investment!
