Just Gone To Synthetic
  • Robbo
    Robbo
    Just switched the girl over to synthetic, flushed the old shit out and in with the new. Got a gallon of Amsoil at $64 a gallon which I thought wasn't to bad.
    Noticing a difference?
  • Robbo
    Robbo
    First thing I noticed was it runs a little cooler, and smoother, I bought the oil from Peter down in Maddington, now where did I put his number?
  • Robbo
    Robbo
    Ok the guys name is Dean not Peter and he is in Maddington and the nmber is 94598603 and it was $64.60 for a gallon of 20W50 synthetic Amsoil. Nice old fellow, by the look of his workshop he tinkers with motorcycle engines.
  • czarek
    czarek
    Is Amsoil better than Mobil1 ?
  • Peter
    Peter
    Who would you believe czarek ???? I have tried Amsoil after using HD mineral oil and it was far better in terms of cooler running temps and less engine noise, but because I can get Mobil 1 closer to home I am now using it and it seems to do the same job as Amsoil. As said on this Forum many times before, there are so many good oils out there I don't think it would matter much which one you used as long as you change em regularly.
  • czarek
    czarek
    Thanks Peter.
  • Robbo
    Robbo
    I had trouble finding Mobil V1 and still haven't found it as yet. No trouble with Mobil! for cars but no V1
  • Peter
    Peter
    Contact Darryl Murray, he is the Australia distrubuter Ph 0418756584 he will tell you where to get it.
  • Robbo
    Robbo
    Thanks Peter, and that will not be the first time someone has told me were to go!
  • Robbo
    Robbo
    I'm running Redline Shockproof in the transmission the whining in 5th gear is hardly noticable, good stuff
  • Peter
    Peter
    Just in case you missed it Redline are now bottling a V Twin Tranny oil, I posted the blurb on the forum somewhere.
  • Mainey88
    Mainey88
    Amsoil is good and reasonably priced, I use it in all 3 holes now
