Brake rotar clean up?
    ride + brake
    Just ride the bike slowly and apply brake gently for 50 - 100 metres most of the rust should  be gone. Now apply brake harder a couple of times (first check for traffic behind you) to make sure brake works fine, job done.
  • ozymax
    ozymax
    remove the pads so they don't get crap all over them, better yet replace them with Lyndalls after cleaning the disc. steel wool or a scotts bright pad then spray with brake cleaner and wipe off.
    Best way to prevent it is ride it often
  • Bashful
    Bashful
    Shit hot, thanks so much guys.
