Online: 1423, Rextheute2022
diy seal,bush driver.
    In the past I've used exhaust tubing.
    The bushes are usually split, and don't take
    Much to fit.
  • Ando
    Ando
    PVC pipe long enough to cover your for tubes and piece of soft timber and a hammer to tap the PVC and drive in ya seals
  • jacko88
    jacko88
    you actually need 2 pieces of PVC the outer piece close to the outer edge of the seal and the inner as protection........plenty of helpful vids on U Tube showing the whole process any plumbing outlet will carry all the sizes depending on your bike or some times you may be lucky at Bunnings
