INSTALL GENESIS 577 OR KURYAKYN TC 24-D CAMS
  • hogdownunder
    hogdownunder
    Hi Guys,
    I am new to this site. My name is Geoff.
    Has anybody installed a Genesis 577 or Kuryakyn TC 24-D Cam in the SE Softail 110 Motor? I own a 2008 a Screamin Eagle Softail Springer.
    I am looking at changing out the SE 255 CAMS.. Any suggestions?
    What are your thoughts?
    Best regards,..
  • Sunny Jim
    Sunny Jim
    Geoff, I checked most cams for my 103 SG. The usual story,  torque vs horsepower. I chose a Tman performance cam 577sm. However , your 255 , tuned right is an outstanding cam for low own grunt. There are some great options eg. tman 555 torqster, 600sm or perhaps the Tman 590. Check Fuel moto and their success with woods cams eg. 222, 555 etc. But, of course there is a pay off. Your compression, exhaust and fuel supply need to be scrutinised. Your expectations are also important.  Big boys cam comparator is a great guide to your calculations.
    Ride safe and sane!
  • Ando
    Ando
    look at the reaper 574 for a 110
  • hogdownunder
    hogdownunder
    Hi Ando,
    Thanks for the input.
    How does the Reaper 574 compare to my SE 255 CAM? Does it have good low end torque?
    How would it compare to the TMAN 625?
  • Ando
    Ando
    run it at 10.2/1 compression and it won,t loose any on the 255 down low and hold on out the back door
    100/100 + in a 110ci
  • hogdownunder
    hogdownunder
    Hi Guys.
    Does anybody know where I can find a competent Tuner to tune my CVO 110 Softail that has the SE Race Tuner Pro fitted? I need somebody that can tune with the SE Tuner..The motor runs hot as it has the Factory SE Map uploaded to the ECM..
    I live in NSW, but I would be happy to take the bike to QLD or Victoria if required..
    Hi Hogdownunder, i saw a CVO 110 Cow at L A Cycles Hoxton Park did useing the stock cam but he did something to heads & tunned it on his Dyno Jet 250i.
    it had a very strong Torque Curve that was long and flat, really good Torque. After that Cow got a few more CVO 110 bikes to do as they road with the guy that owned first one. i only had to look at that Torque curve to know it would be a very quick bike.
    If you do a google L A Cycles Hoxton Park rd Hoxton Park will get phone number.
  • hogdownunder
    hogdownunder
    Hi Krash,
    Thank you for your reply.
    I will look up LA Cycles at Hoxton Park.
    Do you know who does work on engines as well?
    best regards,
  • hogdownunder
    hogdownunder
    Hi Krash,
    OK. Thank you..
    I will give him a call..
