Online: WideglidingNZ
Replacement Audio
  • HIALEAH
    HIALEAH
    My System died today on my '07 Ultra & I was wondeering can anyone reccomend a replacement model other than the stock Harley one, Ideally would have ipod connectivity
  • HogBag
    HogBag
    Hi I have been running a sony biktronics set up for 7 years with zero problems and the headunit gets wet everytime it rains or I wash the bike. My hog tune speakers are starting to sound tinnie and need replacment but not sure if I will take them up on the liftime warranty.
    http://www.biketronics.com/
  • ozymax
    ozymax
    no need.
    2012 road glide.
    Kenwood head unit, Hawg Wired head unit mounting adapter, amp, speakers and power adapter, all original hand controls work. Tried biketronics power setup but would not work the original hand controls
    Hawg Wired have adapters for almost any head unit.
    Be aware most head units are NOT water proof. I just have a plastic bag and rubber band in my bags in case I get caught out.
  • jay73
    jay73
    A friend of mine also had an issue with his 2011 Street glide. The people who make the stereo for the SG have an exchange set up where you give them your old one and they supply you with a new one at half price. Check with a couple of bike shops but that's what he was told.
  • HIALEAH
    HIALEAH
    Going with the Sony DSX-S100
    Kicker CS-67, 6.5"  Speakers Front & Rear
    Hawg Wired HUA470 Universal Radio Install Kit which is just a plug rather than the cable that Biketronics offer.
    Man thats some adapter, is it multifit?
  • HIALEAH
    HIALEAH
    Radio Install: HUA360
    Harley Universal Radio Adapter
    Want the features of a DIN radio without losing your hand controls? Hate the idea of hacking up your stock wiring harness to make it happen? Our HUA360 Adapter allows you to plug and play your choice of supported radios (steering wheel controls interface) directly into your stock wiring harness without giving up your hand control functions. No programming, no messing around with resistor networks, just plug your stock audio harness into one side, terminate your radio's harness into the other, and you're wired.
    Compatible Bikes
    FLHX FLTR FLHT
    '06-'13 '98-'13 '96-'13
    Key Features
    Supports Sony, Pioneer, Alpine, Kenwood, JVC, and Clarion
    Integrated H-D audio harness connector
    Wired remote / steering wheel interface connectors
    Fast response time through hand controls
    Utilizes many aftermarket radio features
    Fully enclosed durable plastic and epoxy resin
    Kit Includes
    1 - HUA360 Harley Universal Radio Adapter
  • HIALEAH
    HIALEAH
    $167.35 Against $221.00 for the Biketronics harness
    Not to bad considering the time saving involved.
  • HIALEAH
    HIALEAH
    http://hawg-wired.com/product_info.php/cPath/51/pPath/96
