Online: beaglebasher, Hilly, speedzter
tank swap
  • dyna gliding
    dyna gliding
    Hi All
    have put this in the workshop section with no responce, have a 06 super glide with a damaged tank and was hoping a 06 wide glide tank mite fit. not a fan of the speedo on the bars, i do like the speedo on the tank
  • dyna gliding
    dyna gliding
    the standard gauge wont fit but would this one with wire mods
  • dyna gliding
    dyna gliding
    i think that one will replace the stadard 5in speedo
  • 883n Harley Convert
    883n Harley Convert
    I think you'll find it will fit. I may have read your message wrong mate, but pretty confident most of the speedo's are standard size and interchangeable.
  • robots
    robots
    Hi,
    Pretty sure the dyna use a 4inch speedo, if you get a dyna manual for your year it has the tank set-ups for each model in it and you could work it out from there
    Thanks
    Robots
