Online: HD17, speedzter
Tune Sunshine Coast
  • Frothychop
    Frothychop
    Be interested to get some opinions on who does the best tune here on the Sunshine Coast. Only had the Stealer do the 1st service and they fitted the pipes, tuner and breather from day one. Would consider Brisbane as well if it was worthwhile,
    Cheers Frothy
  • ozymax
    ozymax
    if your going to Bris then go the south side to ProCycle Dyno
  • TJU
    TJU
    + 1 for ProCycle Dyno ... Fred knows his stuff when it comes to Dyno work .
    Tim .
  • sic-puppy
    sic-puppy
    + 1 more for Fred...
  • HWG
    HWG
    Don't know any on the Sunshine Coast, have used ProCycle Dyno about 3 years ago, highly recommended by me, 110% happy with fred.
  • ozymax
    ozymax
    I am sure there are others around but you will be hard pushed to hear a bad word about Fred or the shop. Even if your not happy with the outcome after you get a chance to really ride it just tell him and he will put it right. You can stand in the box while he does it if you like or walk up the street to all the other brand shops or GA to fill in the time.
  • TJU
    TJU
    Frothy , if it`s not asking to much what type of money did Sunshine Coast want ... as mentioned above Fred is the go to guy for me but Dyno work isn`t cheap ... depending what you are getting done ... after I put on pipes ... High Flow Air Filter ... and purchased a Power Commander 5 ... the Dyno work was near enough to $ 400 . 00 .
    Hope that gives you some idea ... the main thing about Fred for me is his easy going nature ... some shops you walk into they are all Righteous and even sometimes give out a bit to much attitude especially considering you are thinking about spending some hard earned wages in their establishment .
    Anyhow hope you get it the way you want it and then enjoy ... Cheers Tim .
  • Dinga
    Dinga
    I think the SE Tuners are so expensive to tune because there such a pain in the ass to tune and so time consuming. Fred's the man if you want the best out of your bike with a tune.
  • Dinga
    Dinga
  • Frothychop
    Frothychop
    Off to have Fred do Dyno 12th Feb quoted $490 initial cost but then adjustment from there small charge. Lotta $$ but with all the wraps he got  looking forward to it :)
    Cheers Frothy
  • EBT
    EBT
    Hi Frothy,
    To have access to a tuner like Fred at Procycle Dyno is a luxury. As far as cost goes he delivers much more that what you pay for. And one thing is for sure is you will be happy with the results.
    Cheers brian.
