Nightrod leaking coolant
  • FAT TONY
    FAT TONY
    Hi Guys
    just wondering if any one else has experienced any issues with losing coolant with vrods  / nightrods
    Looks like it might be coming from the radiator
    Not even 3 years old  - its a 2011
    I originally thought it was coming from one of the lines
    If it is the radiator, would it be worth fixing or better to go new
    I think a new radiator is around $500 plus
    might be worth seeing if the local radiator guy can patch it up
    thanks
    Tony
  • ralphski
    ralphski
    Try going back to the stealers, and give them the sob story etc.
    I'd be very surprised if they helped, without costing $$$$$$$$$$$$
    Depending on the problem, i'd try and get it repaired by a radiator specialist.
    Have you had issues with over-heating ? low coolant levels? etc. that may have caused this problem?
  • Sweetas
    Sweetas
    I noticed White spots on my engine when I took the bike into get some parts fitted, asked them to have a look and they said the thermostat was bust.
    This is a 2013 Nightrod. Now I am waiting up to 3 weeks for the repair as parts coming from the states!!! No bike over xmas make for a unhappy husband!!!!
    Jarrod
  • MADOGA
    MADOGA
    The leaky Harley issue was fixed back in the 90's
    then they fucked it all up again putting water into some Harley's.
    At least air cooled dont have this problem.
  • FAT TONY
    FAT TONY
    well, the news not good, it looks like its the radiator
    new one is around $800 just for the tank
    I'm looking at seeing if i can get the old one fixed, looks like that will be around $120
    but no guarantees it will last
    fucked if i do, fucked if i dont
  • grpawalky
    grpawalky
    Hey T, any luck with the radiator fix mate?
    Tony, you say you hit the back of a Toyota and caused $4,500 damage to it. I'm assuming you made an insurance claim and already paid your excess. If you can establish that the same collision damaged your radiator, couldn't you have the radiator replaced under the same claim and excess payment?
  • ralphski
    ralphski
    $300, good result.
    Garden Island.....
  • grpawalky
    grpawalky
    I think ya better sell that sucker T.........to me ;-)
