Shockie air pump
  • Canetoad
    Canetoad
    Hi All, I am thinking about getting a shockie airpump and I know HD make a pump ($68) I was wondering if anyone has any other information on alternatives or had purchased any other type of pump that is as good please.
    Thanks in advance.
  • markwoumla
    markwoumla
    Mate , I have the Harley pump for the air shocks. Works as advertised. You don't get any air discharge with the Harley pump when you disconnect the hose , and you have the gauge to tell what pressure you are running . I heard some use a cheap kids bike pump, but them you have to work out what air pressure you have. You can search on the net and find something similar and cheaper. Contact Harley Heaven , a sponsor here and see if there cheaper. Personally not worth the messing about, get the HD pump !!
  • Canetoad
    Canetoad
    Thanks for the info guys..... may just order the one from Tiawan
  • blueystar
    blueystar
    The HD ones are made in Taiwan to
  • Firestorm
    Firestorm
    The HD pump is a very neat, small in size and solidly made. Don't bother with a cheap copy.
  • Chaser
    Chaser
    Why would you bother with a copy to save @ $20? At least with the HD one you are covered with a warranty. If the cheapie breaks, you pay the postage (that's if they will accept it back)
    I saw a ginuine HD one on eBay au for $30 the other day.
    I have one and it works great.
  • Chaser
    Chaser
    For anyone who hasn't used one before, the pumps are soooo small, but you need to literally pumps once and it goes from 30psi to 50psi in half a pump. It certainly wont wear out quickly.
  • Deadwood
    Deadwood
    I bought a digital one, works great.
  • Canetoad
    Canetoad
    bloody hell, sure making me think a bit more guys.... and I did check out that ebay one but didn't win it.
  • conmore
    conmore
    +1 on the HD pump. Have one, works great and doesn't let air out when you disconnect it!
