Quiet Air cleaner
  • conrod
    conrod
    My softail goes well, but the intake noise is too much, for me that is, so was looking for a new aircleaner to replace the SS one
    Found a colmplete air cleaner on ebay (love it)
    Fabricated an adaptor from some 5mm Aluminium
    Fitted it to the E series S&S carby
    And bolted the cleaner on
    Now all I need to do is airbrush the "na
    I've never paid any attention to the sound my aircleaner makes...I guess it's not able to compete with the pipes...
  • HogBag
    HogBag
    My bike makes a very loud popping noise under load through my S&S air cleaner when I'm running dual headers and no noise when I run the 2-1 road rage. My guess is the stepped 2-1 scavenges the cylinders with no reversion coming back through air cleaner.
    I understand why you would change air cleaners as it is loud and drowns out the exhaust noise under load.
