speedo combo for 04 fatboy
  • pommie01
    pommie01
    i have been looking for a speedo combo to suit my 04 fatboy but i dont want a digital speedo. there seems to be no end of 08 and up but 04 to 07 they dont make any more. will a 08 model fit mine as a few people have surgested might ? Any help would be greatful thanks
  • Retroman
    08 and up are 6 speed , your bike is 5 speed ( although the 07 was 6 speed as well !) There's a green " 6 " light in the dash
    That's the first " technical reason " I think you'll have trouble
    There's also extensive changes to the wiring harness between 2004 and 2008 and up
    They certainly did have combo speedos for the 2004 back in the day , so a search of ebay canada may turn something up ? ( They're Km/H !)
    UK spec speedos often have Miles and K's so maybe there ?
    Will they " fit" in the tank ? , most likely as same size speedo , will the multiplugs work ?? That's the question
    Where are you located ? If you're in Perth WA I can lend you a 2008 Speedo to "try" or at least look at ?
  • pommie01
    pommie01
    thanks for the offer Retroman but i live in lara geelong. I have been searching ebay global for near on a year now with no luck. there is some speedo combos out there but all have a digital display which im not to keen on or are in miles from the usa.
  • Squarke
    Squarke
    Hey Pommie
    In my garage (somewhere) is a standard speedo off of a 2010 fatboy we could fit it up and see what happens check plugs ect and i am in geelong'
