Online: speedzter
Will digital/combi speedo 74717-10 fit a 2007 Softail?
  • Stuboy-2001
    Stuboy-2001
    Hi there
    Does anyone know if the combination digital speedo/analog tachometer, part # 74717-10, will fit a 2007 Softail?
    Online it say the gauge fits '08-'10 Softail models with a 5" speedometer.
    Are the plugs different from 2007 to 2008?
    HD makes a combi speedo which fits '04-'10 Softails, while the speedo I want fits '08-'10 Softails.
    So they overlap by a couple of years, which makes me wonder that the plugs must be the same?
    Has anyone fitted a 2010 speedo to a 2007 model Softail at all?
