Online: B0nes, WideglidingNZ
BOBBER BUILD
1/3
  • jocky
    jocky
    Got all my stuff ''that i could afored at the moment'',,xmas eve big thanks to'' walka''. As you can tell from the photos,looking mounting the tank
    where it sits,as i dont want it sitting to high, my question is,,is it ok to drill through the frame and weld a squash bung though the frame to
    take the mounting bolts and rubber mounts? Also out of curiosity the frame is a kraftec 180,,what is it constructed of? and would the bungs
    need to be of the same material? thanks for your help&replies.....Jocky
    FIRST MOCKUP
    The frame is mild steel and looking good
  • CairnsFXDF
    CairnsFXDF
    I agree, weld new mounting points on the tank to relocate it, welding the frame being a stress point if not done right can make the parent metal around the weld brittle as well as legal ramifications.
    But on another note i do like the direction your taking and I'm looking forward to seeing this project take shape.
  • jocky
    jocky
    thanks for your replys/thoughts fellas,thanks for your intrest cairnsfx, got it all in my head what i want to do''mental image'' if you like.
    just got to pay for the ideas to come out......Jocky
  • jocky
    jocky
    does anyone know where is the best place to get a spring seat pref aussie made look at so many on ebay
    postage is the killer,plus the brackets seem to be xtra or only half there,surely someone makes a good seat ''bobber''
    with  all brackets suplied?.....jocky
  • jocky
    jocky
    thanks scouser, found a seat straight away ''caught my eye'' itwas a match for my theme i am taking with this bike.
    good site to.....jocky
  • jocky
    jocky
    Hi fellas,been a while but here is an update on what ihave done so far.
    seat & tank bungs welded on and fitted up
  • Hound_Dog
    Hound_Dog
    Love the seat hinge Jocky. What brand is it mate?
  • jocky
    jocky
    bitwell...from lowbrow customs.....jocky
    i don't see why people build or buy rigid's then put a spring seat on  esp these small terry type of seat's  , if not mounted proper or when the front mount wears out , that it will the seat move's left & right  & feels like a flat rear tyre  & the spring without a shock , when you hit one bump it will keep on bouncing up & down up to 4 time's so by the time you hit another bump more up & down  butt with that seat angle down @ the back  with no back curve up  you are  going to have sore hands from trying not to slip back on the rear mudguard when you throttle up , esp with foward controls because you can not use you legs to pull forward  ,  front springer forks  also need a shock damper  or you will pogo from bump to bump,  esp on our roads , iv'e 1st build choppers in 1975  & judge some bike shows ,  can tell just by looking @ the pic's without a test ride ,  might save you some work in the future, esp after you painted , best build the bike test ride 1st then pull her back down then worry what colour , if you have't built bike's before you don't want to learn the hard way . good luck
  • jocky
    jocky
    thanks for your thoughts daddyracer56, yeah its my first build,yeah i will make mistakes, i do understand the probs with the seat angle but that is the look that i was after.
    same with the front end,...but after all isnt it the look that makes these bikes and standard harleys what they are.also understand the practicality side of things:eg:seat.
    but all that said i dont have a problem with experienced fellas like you pointing things out,so first timers like me dont make to bigga stuff up.
    on the front end, personally i dont like to much the look of the shocker on the front,will see for myself how it rides in time to come and if i dont like it i will look in to installing
    one.also will definately take it for a run before its painted.....jocky
    I've got nothing against Ridgids. i road some Ridgid panheads. but Like daddyracer56 your got it wrong. you can have a ridgid bike that looks great & feels great. if a bike don't feel great to ride makes you hate riding. you want a bike that feels as good as it looks, to ride & enjoy it.
    But if you want to do it this way go ahead. the most important par to me is the motor.
    good luck with your build Jocky, what motor & gear box? & will it be kick start?
  • jocky
    jocky
    gday krash,what is it that i have got so wrong?is it the seat:eg no up turn on the seat, or is it the seat angle,in regards to the motor,just standard sportster motor & box,still saving for a donor bike
    at this stage.i am not out to reinvent the wheel here just an enthusiast giving it ago....jocky
  • jocky
    jocky
    got a bit more done on my build,bracket made and welded onto front guard& fitted up
    good to see some action
  • jocky
    jocky
    your right walka,my build will probably be slower than most due to circumstance,but i will get there and have fun along the way,and headaches for sure
  • Neale
    Neale
    Nice looking set-up. I want to do a sportie in a hardtail myself. I want it with a twin disc front end, fork gaiters, stockish rake with a hardtail arse. One day.
  • Neale
    Neale
  • jocky
    jocky
    give it a go neale,i am sure you will enjoy the challenge.....jocky
  • PaulT
    PaulT
    that bike is going to be soooooo nice, love those wheels.
1/3
