Online: Soapbox2627
LED Bulbs
  • Tapey
    Tapey
    I just got a LED bulb put into my rear tail light and it looks shit hot. Im just letting people know that it can be done with just a new LED bulb.  They cost about $20.00 for just a standard one but go up to about $60.00 for flashing and rotating ones. They just take out the old normal bulb and put in the LED bulb. I didnt know this was all that needed to be done, so those of you that didnt know....do now.
  • BACAMICK
    BACAMICK
  • Hoodaman
    Hoodaman
    Never heard of them...where did you find it???
  • SuperGlide
    SuperGlide
    Good tip, will check out MCA on the weeked.
    Alot better than buying $200 smoked one fm H.D!
  • blueystar
    blueystar
    the road sweeper has a 64 led board in the tombstone tail light and the brake light is bright just ask crasher he used to complain about the led spinning light bulb i used to have you can pick these led light bulbs up on e-bay pretty cheap
