07 roadking misfire.
  • moffycc
    moffycc
    Help pls .Took her out this mornin 10 min down the m1  started to misfire like full ignition shut off speedo back to zero then etc pulled in fueled up but got worse as she got hotter,just got her home she was crap speedo all over the place major misfires.
    had the battery checked its ok connections ok .  buggered around couple hours tightened everything up out for another ride sweet until she got hotter just got her hm again.  any advise or ideas would be much appreciated.  cheers moff.
  • HogBag
    HogBag
    What year bike.
    It sounds like a main fuse (circuit breaker) is getting hot and shutting down. Could also be the crank sensor if its a later model.
  • Retroman
    Has the bike an early version power commander ?
    Or a Thundermax ECM ?
    Back in 2007 these were the "dog's bollocks" for tuning
    Even tho' they were'nt !! , now they're just a liability with wiring issues in my experience
    If it has either installed , my money's on the wiring loom for the add on product
    Seen it before , exact same symptoms you are describing
  • moffycc
    moffycc
    its a 07 96 cu with sept fitted and its been fine till today ,soon as she heats up the misfires startup, had it idling when hot back hm but rev her up neutral light and tank lights dim out misfire then shut down let her cool down seems ok. tks fellas for the input , Hogbag would the crank sensor be a problem with that year?
    I'm sort of with fat55 ,coil maybe!!
  • Retroman
    I've seen crank position sensor problems , rare but I have seen them
    You should be able to raise a " fault code " if it is . Fairly straightforward to replace if it is.
    Coil problems are even rarer ( in my experience anyways !)
    Is your tuner an older SERT or a younger " Super tuner ". They're quite different
  • moffycc
    moffycc
    its the orange pro super tuner Retroman. fault code was the first thing i checked out on the road was p1353 cleared it then and theres been nothing since even after runnin like shit etc.
  • HogBag
    HogBag
    I would check the main fuse (left-side cover)first for corrosion as it sounds like a total power failure. Ignition has to be on when you pull the fuse and on when refitting it. Check the battery earth at battery and especially the gearbox as these come lose on the early 07 bikes. It could be the crank sensor but that won't cause a total 12 volt power failure
  • moffycc
    moffycc
    tks HogBag will do ,have checked some ,hes a tricky little prick the gearbox earth got a spanner on there just.
  • Retroman
    Yes , corrosion and bad earth is what I'd be looking for
    ALSO the ignition switch itself can get all blue copper corrosion thru' it
    I've seen that several times and fixed it , Speedo etc lifted and take out the switch unit.
    Big CRC clean up , then lube with chain lube ( I don't have dielectric grease in the shed !)
    Worked perfect on 2 bikes , a 2000 Deuce and a 2006 Dyna , both with "switch on the tank" like a Softail
    Costs nuthin' but time and effort that one
  • HogBag
    HogBag
    Good call on the ignition switch retroman
  • HogBag
    HogBag
    Also pull the male conection off the ECM when the main fuse is pulled and check for corrosian on any off those pins and re-plug before the main fuse goes back in. Go steady making sure you don't bend any pins.
  • moffycc
    moffycc
    Check check check no corrosion stator and regulator all good .run this morning going good then shit again 3 go's to get her hm last 1 was a half k tow. Rang a mate bought round battery banged her in wamo fired up straight away. The 2 and bit year old battery I pulled out read 13.13 v but wouldn't turn her over. So hopefully all good with a new one. Won't be buying it from batterywworld they can get fucked. Haha
    Well fingers crossed. Cheers for all the import it was a weird 1
    Tks moff.
  • HogBag
    HogBag
    Its a turkey shoot buying batteries as my original HD battery lasted 6 years and the replacement HD lasted 10 months. Deka make HD batteries and there one of the best available downunder.
