help wanted solo saddle bag mounts
  • mato_h
    mato_h
    hey guys i wanted to make my self a solo bag for my sporty but i am not very sure on the mount points can some one please take some pics of the bag & mount points on there bike. i have been doing leather work for a short while and have made a solo bag for my mates fat boy i will throw up some pics to show you
    all coments welcome
    Mat
  • careyman
    careyman
    I want one for my 2008 883 custom....(it hangs low to the ground tho?)
  • mato_h
    mato_h
    I need some pics of a sporty mounting points . Then i can make one mind you its wont be as big as that one
    The fat boy was easy and yes it dose look low but dose not touch the ground at any time and my mate pushed it hard some times LOL
  • mato_h
    mato_h
    this is what i want to make but just not 100% on the mounting points thate why i wnat some pics
  • 98superglide
    98superglide
    Can you get some pics from licks cycles , larossa, or bad g customs? They do great solo bags, or Pete at plunder dog.they might be able to flick you some pics.
  • Fire511
    Fire511
    I have made one for my 48. It mounts to the 2 bolt holes for the pillion peg on the left side. I then got it chromed so it wouldn't rust when the solo bag touched it. I have now also made a bracket and had it chromed for a mates Dyna, they look great and the solo bags sit perfectly. I will try and put some pics up.
  • mato_h
    mato_h
    Fire can you get me some pic's please the only other thing i have found was using straps but i was umming and arring
  • Bandageboy
    Bandageboy
    I have a La Rosa on my 48. Mounts on the brake line and two points on the frame, super easy and looks great!
  • Fire511
    Fire511
    I will get some photos up asap. With my bracket the bag doesn't touch the bike or the swing arm so no rubbing but still sits nice and close to the bike.
  • GT 1200
    GT 1200
    If you can work it out you would sell some here.
    I was thinking of getting a "Licks" but have not got around to it yet.
  • Fire511
    Fire511
  • Fire511
    Fire511
    This solo bag set up works great and matches the lines on the bike. A lot of time was spent in the shed with a beer working this one out.
  • Fire511
    Fire511
    If you can see in the top photo I have made my own side plate holder with two LED lights in it and yes it is visible from 45 degrees from the rear and is legal. I also made up some foward control heel rests which are great on the hwy. I will put up some better photos.
  • Fire511
    Fire511
  • Fire511
    Fire511
    These are the heel rests I made, great on the highway.
