Online: Soapbox2627, FONTANA302, Ultramick
Exhaust balance pipe gasket leak?
  • Fa1c0n
    Fa1c0n
    Hey,
    Just noticed one of the gaskets that connects the rear muffler to the balance pipe seems to be leaking a bit of exhaust.
    Just wondering how bad this is and how urgently I should be replacing it?
  • terroristone
    terroristone
    No biggie, very common. If your bike still has warranty you can have the dealer change it for free. Otherwise if your near me go buy a gasket and I'll fit it for you no charge.
    Regards - T1
