indicator problem 95 RK
  • robert65
    robert65
    hi guys
     I have a problem with my indicators i have just put new bars on the bike ,when i put my right side indicator on it works fine, but when i put my left side on they all come on , I have double checked all the wiring and everything is in order and i also put the old bars back on to check the wiring and it still does the same thing . would anyone have an idea what this could be,any help would be appreciated.
    thanks.
  • robert65
    robert65
    thanks RT i'll give it another look
  • robert65
    robert65
     well RT
    Ihave fixed the problem went to the local shop and tried a new module for the flasher unit and it worked a treat ,I T'S ALL FINE NOW thanks for your input .
    owe you a beer for your help mate .
