Removing marks on matte black
  • Carmo
    Carmo
    G'day,
         I thought it would be a good idea to use a tank protector. In hynsight it achieved the opposite. Mid way up the tank where the tank 'protector' ends it has left a mark / ring all the way around the tank from where I can only guess it was rubbing, ever so slightly. The matte black paint has changed from its original colour to now have a partially shiny look to it which can be obvious in certain light.
    Short of getting the tank re painted, are there any mesures I can take to reduce / buff out the mark?
    If reprinting is the best option, does anyone know of an average price a 17 lt sportster tank would cost to get re painted in matte black?
    Cheers.
  • TC883
    TC883
    Sorry Carmo, but the short answer is your stuffed. Buffing only makes the matt paint shinier and hence the problem gets worse. I have a similar issue where I put the smaller 48 seat on my bike, leaving a mark on the rear guard where the original seat rested against the guard and rubbed the paint shiny. The offical blurb from Harley is that the denim paint is supposed to "wear" and "weather" like a pair of jeans, which is code for you cannot do anything about chips, scratches or rub marks. The genuine Harley denim paint cleaner is the best stuff to clean it with in my experience, and using it may reduce the visibility of the marks, but they will still be there, sorry. TC
  • Rocky2010
    Rocky2010
    There is a trade off having Matt Paint, looks great but there isnt much you can do with it.
    Probably a stupid question, but what if you used a REALLLLLLLLLLLLLLLLLy fine sandpaper on it to remove the shiny layer?   That's if a repaint is the only answer..
  • Carmo
    Carmo
    Too bad to hear that, respray it is I guess. Can only learn from this.
    Cheers fellas
  • S3R0
    S3R0
    Have a Fatboy Lo myself in the Black Denim. The paint is the same Vivid black base color but has a matte clear coat over the top that is unforgiving to any marks.
    3 Products i have used for cleaning denim - HD Denim Cleaner, Windex & Rubbing Alcohol as last resort.
    Otherwise your up for a full repaint unless you want to try (at own risk) things like 0000 grade steelwool, claybar, sand/polish the matte untill its a satin finish.
    Check out some of the posts on the US HD Forum as most of the above have been tried by them.
  • 98superglide
    98superglide
    I had a sporty tank done in it. Marks so daily. I got told cold water with I dishwashing liquid....
  • 92Fatboy
    92Fatboy
    Panel shop will have heavy duty industrial grade compound and it should buff out .
