PULLBACK BARS FOR A 2007 ELECTRA GLIDE.
  • HIALEAH
    HIALEAH
    I am finding the reach on My '07 Ultra hard on My back, Has anyone fitted different bars that give a greater pullback???.
    The only option Harley offers fits 2008 & later.
  • paulsails01
    paulsails01
    I am not sure about the 07 FLHT's but you might find OEM #56176-08 bars will go very close.
    Assessing these Bars against my 09 FLHT they are very close to my stock #55924-08 with about a 2" pull back being the only difference.
    Best to contact your nearest HD dealer for compatibility, he will have the 07 FLHT catalogue which he can do a cross reference.
  • groover
    groover
    Can't see why 08 bars wouldn't fit a 07. Same bike really before they went to the wider rear end in 09.
    Most people fit either the Reach Bars or Heritage Bars.
    Reach bars accept the wiring internally.
  • groover
    groover
    Ahhh, now I remember.
    08 came out with Fly-by-wire throttle.
    Bars should still fit though, only difference is they are notched out on the end to accept the FBW throttle control.
  • paulsails01
    paulsails01
    Yes, dead right groover! this should not impede installation on 07 FLHT, may require some rounding off at throttle end.
  • rooshooter
    rooshooter
    the harley pullback bars worked fine on my 07 flht
