Which Pipe ??
  • Fritzables
    Fritzables
    Hi All,
    Well, I've made the move. As a former Jap Bike rider, today I bought my first bike outside Japan and chose the 833 Iron (2013).
    The plan is to fit a K&N Aircharger Filter.
    And Performance Pipe.
    TTS Mastertune to sort the map out.
    Originally I was going get a set of V&H Shortshot Staggered pipes, nut with further investigation, these will rob a good part of the low end grunt due to their short length.  Not sure if I can tune this out with the Mastertune as these pipes are my prefered.
    Continuing the search, I have come across a brand I have never heard of.  It's the Freedom Performance Independance Shorty.  Both of these systems are 2 into 2.
    If there are issues with loss of low-end - what are peoples thoughts - do I look at the Freedom pipes as they are longer??
    Pete
    PS: Take into account there is a 1200 Kit planned.
  • slapster
    slapster
    Gday Fritz & welcome to the forum. You may wanna repost your thread over in the sporty section mate, probably get a better response.
    Slap.
  • Fritzables
    Fritzables
    Thanks Slap.....
