2012 softail now 106 cub dyno run
  • CairnsFXDF
    CairnsFXDF
    Damn mate nice work, going to do the S&S 106 next year for mine.
  • carbon fibre
    carbon fibre
    is that turbo lag 2000-2750 rpm??
    Nice power indeed. Still pulling over 100tq at redline, and HP only just starting to slow !
    She'd be a fun ride from 3k up !
    Here you go !
  • ozymax
    ozymax
    Great job Davo, Be nice to have the dyno access to make and check changes the way you can. Us mere mortals just get 1 or 2 goes. Your a lucky man indeed but access is no good if you don't know what your doing I guess.
    Look forward to the final result
  • newschool
    newschool
    Have heard a lot of great feedback for S&S 640G's, what cranking pressure are you running?
  • Dinga
    Dinga
    Nice one Dyno, bet she pulls like a train. 200 Hp with a turbo, would like to see that graph when your done.
    Why would you want .7 lift on a 4 valve head?
    I always thought that half the reason for the 4 valves is that you can run lower lift cams and still get the same flow as a high lift setup.
  • newschool
    newschool
    What fuel did you use on the 106 run above?
    Nice work on gettin 1.25 HP per CI
