Online: beaglebasher, John.R, speedzter
2011 deluxe security pin retreive
  • johny
    johny
     hi all  i    bought a 2011 softail deluxe owner didnt no the five diget security pin no can anyone tell me how to retreive the number  thanks
  • aido
    aido
    I think you will have to take it to a dealer
    You should be able to reset the pin if you have the FOB, instructions below.
    Might take you a couple of times to get it right.....
    Let us know how you go.
    To reset the code with a HFSM (Hands Free Security Module) equipped bike, you will:
    1) Have your key fob near the bike
    2) Set your kill switch to off
    3) Quickly turn the ignition switch on, off, on, off, on
    4) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
    5) Press and let go the right signal once
    6) Current PIN number will be displayed on odometer
    7) Change the PIN by pressing the left signal until the desired number is reached
    8) Press the right signal to cycle to the next number and repeat step 7
    9) Turn ignition off when 5 digit PIN is satisfactory
    NOTE: Steps 3 through 5 must be completed in quick succession of each other.
    Now you can have the bike armed, and disarm with the PIN (example PIN will be 25522 in the following steps):
    1) Ignition switch to on
    2) Immediately press both turn signals at the same time (red key light on you speedometer will flash rapidly if done right)
    3) Press and let go the left signal 2 times
    4) Press and let go the right signal once
    5) Press and let go the left signal 5 times
    6) Press and let go the right signal once
    7) Repeat for each of the last three numbers of the PIN (left 5 times, right once, left 2 times, right once, left 2 times, right once)
    8) Red key on speedo will stop blinking if done right (security has been disarmed)
    NOTE: Steps 2 through 7 must be completed in quick succession of each other.
    To reset the code with a TSSM (Turn Signal Security Module) equipped bike, you will:
    1) Set your kill switch to off
    2) Quickly turn the ignition switch on, off, on, off, on
    3) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
    4) Press and let go of your fob button twice (press fairly hard, it's designed to resist being pressed by keys and whatnot in your pocket)
    5) Current PIN number will be displayed on odometer
    6) Change the PIN by pressing the left signal until the desired number is reached
    7) Press the fob button twice to cycle to the next number and repeat step 7
    8) Press and let go the right signal and turn ignition off when 5 digit PIN is satisfactory
    NOTE: Steps 2 through 4 must be completed in quick succession of each other.
    1) Ignition switch to Accessories
  • mickle
    mickle
    http://www.youtube.com/watch?v=aw_87JtRy8U#t=13
    This might help also.
  • johny
    johny
    thanks for the advice forum legend tried that about 5 times still the pin number didnt come up maybe on the 2011 deluxes is diffrent cheers
  • FXST11
    FXST11
    http://www.youtube.com/watch?v=aw_87JtRy8U   copy and paste this to watch a video on checking & changing security codes.
    I have a 2011 FXST, to check your Code, Turn the Ignition to On ( at the tank) Then on the bars is the Run / Off switch. This is what you need to go Run then Off then Run then Off then Run ( this time leave set at Run ) then press Left Indicator 3 times then Right Indicator 1 ( once) then your code will come up where the speedo reading is.
    In my manual it says left blinker button Twice, but i tried 3 times as per video and it worked.  Just remember it is Not the ignition on tank you turn On / Off,  You leave this ON.
     It is the Run / Off button at the Throttle.
  • johny
    johny
    thanks for the imfo fxst11 at first it didnt work then i tryed left blinker twice it worked got my pin number happy man cheers for that
  • FXST11
    FXST11
    Your welcome Johny
