Online: Stuart
883 superlow front guard
  • ozymax
    ozymax
    I need some dimensions for a front guard.2012 model although other years maybe the same, I have no idea.
    If any one can give me the measurements below I would appreciate it.
    A bolt hole centres
    B between mounting struts and thickness if possible
    C Height from mounting hole to top of guard.
    Max
  • terroristone
    terroristone
    Measured off my 2011 iron A- 67 B- 117 C-145 give or take a few mm.
    Which concers to B, what do you mean by thickness? Thickness of the guard?
    T1
  • slapster
    slapster
    Superlow has different size front wheel? Is the guard the same? Just a thought..
    Slap.
  • ozymax
    ozymax
    yep guard is different
  • terroristone
    terroristone
    the picture lists for all the models
  • ozymax
    ozymax
    that's true and I apologize for my poor copy / cut / paste skills however the topic is
    883 superlow
  • terroristone
    terroristone
    Ask user "Superlow 11" if he can take the measurements for you.
    T1
  • Superlow 11
    Superlow 11
    I'll take some measurements when I get home, if you pm you mobile # I will text them to you if you like , cheers shane
  • ozymax
    ozymax
    Dropped into to dealers this morning with a tape and measured one
    A = 70mm
    B = 148mm
    C = 125mm
    Now to find one at a reasonable price.
