Online: Stuart
older member
  • rob.williams
    rob.williams
    .As i get older, i may need the ease of a reverse gear. Just enquiring about which is the best and approx. cost, and how has it made your life easier.
    Thanks
    Rob my reverse gear is nearly 50 now and i think she is the best, as for cost well its still ongoing and sometimes makes my life easy but can easily make it very difficult as well   smiley
  • rob.williams
    rob.williams
    I hear what you are saying PB, alot of on going maintenance and never ending polishing.
  • rob.williams
    rob.williams
  • HogBag
    HogBag
    I will be fitting a reverse one day in the future as my plan is to add a sidcar when I'm to old to hold the bike upright. There's quite a bit of info on the american sites if you want to do homework on them.
