Dyna Exhaust Question - Whats the difference
  • 883n Harley Convert
    883n Harley Convert
    Hi guys,
    This an of interest kinda question more than anything else.
    With the exception of the O2 sensor plugs on the later model FXD's; are there any othe differences in the mounting points.  I was speaking to D&D about a Bobcat exhaust for my 1998 Lowrider; acknowledge that I would have to put bungs in the O2 sensor holes, but would like to understand whether the mounting bracket that attaches to the transmission is the same? D&D reckon the headers will mount with no issues at all, but not too sure about the mounting bracket.  Anyone looked at this in the past with any exhaust?
    I know the slip ons are interchangeable all the way through basically the same..............
    Waz
    I can't see there being much difference.
    If you're prepared to mod the mounting bracket and have some metal skills, you
    Should be fine.
    Try and find twin cam to compare against.
    The main thing to check is around the gearbox, and oil filler.
    883n Harley Convert
    Thanks Speed mate, I'll see if I can pick one up from somewhere and work it out. If I cant well, I'll just have to find an alternate exhaust that performs well and looks great at the same time!
    Waz
