chain and sprockets
  • graham praljak
    graham praljak
    im building a custom chopper and i want to use a chain and sprockets instead of a belt,im using an ultima frame based on the 1984 to 1999 softail frame.ive got a 200mm rear tyre.so was just wondering what i need besides rear sprocket,chain and front sprocket
  • blueystar
    blueystar
    Chain gaurd
  • graham praljak
    graham praljak
    ive already got that,i was thinking i mite need a spacer for the front sprocket
  • blueystar
    blueystar
    See how it lines up and go from there if you need spacers
  • Crowy
    Crowy
    Assuming your rear wheel is centred & straight.
    Mount the rear sprocket & space it as to miss tyre & frame.
    This will give you the off-set of your front sprocket.
    As mentioned you can buy front sprockets with offsets.
    If you can't PERFECTLY match alignment with your front sprocket,
    You may (if you have the room) have to re-aligne the rear sprocket
    Work along those lines
  • graham praljak
    graham praljak
    thanks crowy,when you put it like that it sounds easy
