Gearbox whine (5th) & oil question
  • Deadwood
    Deadwood
    Howdy, noticed when i bought my bike, 2009 Road King, it had a whining noise in 5th gear only so upon changing engine oil i dropped the transmission oil and threw in some Redline Heavy Duty shock proof hoping to reduce the noise all to no avail. Having done some brief research it seems that the 5th gear was straight cut not helical(?) and in turn is a normal sound.
    Has anyone had any luck in eliminating the whining noise and what oil did you use in the primary?
    Cheers.
  • AJ56
    AJ56
    Mine doesn't whine... Anymore... 70K... 07 heritage
    Deadwood, Your pipes must be too quiet! lol
  • Deadwood
    Deadwood
    Thanks guys. Who needs a 6th gear indicator on the speedo when you know your in 5th eh.
    Tell you what FLHuTChU, Road King is much quieter than me old Dyna now the pipes are well and truly behind me.
    I'll look into that oil Hilly.
