Iron 883 Handlebars and Headlight fairing
  • Abdul883
    Abdul883
    Hi Guys
    What are the options for handlebars without changing the brake lines and stuff. as in how high can i go with the risers to put drag bars on it also is there a Seller for the Matte Black headlight fairing in melbourne, every seller is from the states
  • terroristone
    terroristone
    Height will be determined by which bike you have, if a 48 it won't be far, the iron brake line will stretch out to about a 4" riser.
    T1
  • Abdul883
    Abdul883
    its a 2013 iron. so i might be able to put 4" risers
  • JOHNO23
    JOHNO23
    Hi Abdul,
    I had 4 inch risers on my iron at one stage, with flat drag bar - worked perfectly.
    Didn't need to change any lines etc.
    what style of headlight fairing are you looking for?
    Johno.
  • terroristone
    terroristone
    You'll have to straighten out the hard line a little, my professional opinion recommends you don't. Do it the right (and safe) way by replacing the whole brake hose!
    T1
  • Abdul883
    Abdul883
    One of these
  • slapster
    slapster
    That headlight cowl is HD part 68129-97, about $150 at the stealer, can be bought non-genuine online for a lot cheaper.
    Slap.
