Online: Rextheute2022
TTS SOFTWARE in MELBOURNE NEEDED
  • buznuts
    buznuts
    Hello guys,
    I have a bike to tune with a TTS and I need to get or know where to get the software to tune it.
    I have all of the update software and everything I could of the website, but cannot seem to get the
    actual programming software.
    Please reply or call me if you can help :)
    Anthony 0425 715 666
  • Retroman
    Way back when I started with TTS , ( after having been using original SERT software ) , I had an install CD with the original "kit".
    I then did all my subsequent "updates" from the TTS Maastertune website , but the laptop was already "installed" from the CD
    I'm still using MT7 files , and as my own bike is a 2008 then that's OK
    I think you're probably doing a bike for a customer ? Well then maybe use his install CD ?
    You'll be onto MT8 files then most likely
    Just install the software updater, and run it.
    It should give you the option to download the software.
  • Ando
    Ando
    Ant get the dude your tuning for to bring in his Disc, That's all I did with the tuner I use over here, takes about half an hour to load up and run the updater
