Online: Stuart
Solid vs braid oil lines
  • Tubbed
    Tubbed
    Anyone had experience with using (or making) solid oil lines
    I'm looking at making them to use on my custom build as I think it would look way better than just braided lines but am unsure if there is any issues like cracking etc
  • Tubbed
    Tubbed
    Would I be right in saying engine wasn't solid mounted and that the lines were from a tank mounted on body of car to the engine  which would have some flex under engine torque but in my case I'm thinking my only problem will be vibration as motor, oil filter and oil tank are all solid mounted to frame (oil tank has small rubber mounts) so hopefully wouldn't crack so anyone used solid lines in same situation as I'm  wanting to
  • El Skitzo
    El Skitzo
    Everyone I've seen do it usually keeps an inch or two section of rubber/braided hose at each end of the solid lines to soak up the vibration and avoid that cracking
