Online: BigKangaroo
Age old question Tires
  • Dutchy Hoogen
    Dutchy Hoogen
    I have recently put stinger wheels on my fatbob. New rear tire is a Dunlop D402 180/55/18. Good tire except in the wet. The blocky standard tires where much better in the rain especially in the puddles. ( would love it if they made them for new size.)
    Anyone out there using anything is this size they think is better in the wet.
    Cheers Dutchy.
  • paulsails01
    paulsails01
    Must be a coincidence!
    I was having a discussion with a very good old mate of mine today and he expressed his concern over the same tyre he has on his 2013 Fatbob in wet conditions, the general concencuss (spelling!) he has from his fellow club members was he should have gone with the Mitchies Com II rear tyre as the guys who have the same sled are more than happy with the Mitchie.
    It's also a general concensise that the Dulops are Dunflops! Michelin, Metz or Pirelli are what you need.
  • Dutchy Hoogen
    Dutchy Hoogen
    Thanks Guys. Tire has only 3000kms but will be well worn out by winter. Going to buy commander or pirelli  put in the shed.
    There is a good thread on the Pirelli Night Dragons in the review section.
    I run them and find them way sticker then the Metz and oddly is damn good. enough the wear so far is damn good
  • Dutchy Hoogen
    Dutchy Hoogen
    Thanks Tussuck i'll have a look.
  • Dutchy Hoogen
    Dutchy Hoogen
    Got the dragon on and it's shit hot.
  • clarkie
    clarkie
    had metzlers and went to night dragons and love em good in the rain and sticky as buggery in the dry,you wont be dissapointed.yes
