Harley warranty
Harley warranty
catman
What happens to my harley warranty if I fit a tab auto tuner?
regards GregGreg
I would imagine like any Manufacturer, If you modify from standard your warranty will be void.
Perhaps if HD are doing the modifications for you, they'd probably cover their parts, modifications and labour etc.
Perhaps I'm mistaken, anyone else want to comment?
P.s. I use the TAB Auto Tuner, let me tell you their brilliant.
CRG85
Has anyone got anything to add to this? I'm looking at fitting exhaust/filter/tuner myself instead of using the dealer. I could probably fit all 3 myself for the same price the dealer would charge for the pipes alone. Would fitting just these items myself void my warranty? I have a 2014 Dyna.
Thanks in advance
pva68
I did just that on my 2014 fatbob. Pipes air and tuner in my garage.
Took the bike back to dealer for oil leak and they fixed it under warranty with no hassle at all.
I think it will only void your warranty if your mods contribute to the problem you are claiming against.
