Online: Rextheute2022
Why is the red ignition light staying on
  • 1stStandard
    1stStandard
    Hi All,
    I was removing the battery tender/ trickle charger from my standard, turned ignition to On, pulled main fuse then set about undoing the two 3/8 bolts that secure the tender to the battery posts. Once removed, retightened the 3/8 bolts, put main fuse back in. However now there is no neutral light with ignition switch on, and when I switch back to off position, the oil pressure light flickers.
    Can someone enlighten me as to what I have done wrong?
    Luke
  • 1stStandard
    1stStandard
    For some unknown reason, whilst I pulled the fuse to come inside to write a post on here, it would seem the computer reset itself or something, cause after posting my problem, went back to garage, put the fuse in.....and now I got nuetral light. Alarm armed too, so I assume its back to normal.
