Online: Stuart
internally wired pull back t bars
    that's why you remove the outer case an tape them tighter so the harness is smaller and does not get caught up like yours has .
    and than use the fishing line &nut to pull it through the new bars if you don't have the string in them
  • bahl
    bahl
    rednuts I'm not concerned about the wiring drama you had but I have been thinking about replacing my buckhorns with pull back tee's, why did you go back to the buckys did you have a problem with the Tee's? cheers.
  • Ando
    Ando
    Fitted and removed a few sets of bars and never cut and soldiered a wire T's included
    I have always unplugged from under the tank, disassembled the plugs and taped up the pins from there takes ten minutes to pull through wiring
