SE MVA Heads on 95 CI
  • newschool
    newschool
    Has anyone used the SE MVA heads on a 95 CI Carby Twincam?
    H-D has pistons available for use with 4" stroke and MVA Heads (22123-08, forged, 10.5:1 for 3 7/8" bore)
    In the SE catalog this combo is not shown in the recommendation table.
    I have ordered a set of MVA heads for my 120 build but might throw on my 95 just for fun.
    would appreciate some feedback from anyone who has done this to see if it is worth the outlay for pistons.
  • newschool
    newschool
    Cheers Dyno, If I fit them, I was intending to check valve clearence.
    I am currently running S&S 570G's, they work well with the  factory CNC ported heads (with Valve Upgrade) and 10.25:1 Mech Comp pistons.
    With the MVA's I would reuse the 570G's but, am concerned that the port size is to large for 95 CI and low intake velocities would cause mixture drop out on a carb motor.
    Have you (Dynoharley) experimented with anything close to this combo?
