Online: John.R, Stuart
Lowering 883 Iron
  • Abdul883
    Abdul883
    Hi Guys
    I seen the lowering block/kits on ebay for about 30 to 40 dollars
    Does anyone know if there is a Australian seller so shipping doesnt take a million years.
  • mickle
    mickle
    If you really want to lower the bike ring Harley City and they will more than likly throw
    them in for nothing, as well as the install.
  • terroristone
    terroristone
    I've got a set of 1" lowering blocks here if you want them, i don't recommend them. Your better off with a good quality 11" rear shock. If you want to replace the shocks i can get you a good price on Ikon shockers and will fit them for free - If you in melbourne.
    Regards T1
  • Abdul883
    Abdul883
    I spoke with Harley city and was told to keep it at the standard height because of my weight. Plus the standard shocks have some minor adjustment on it anyway.
  • TC883
    TC883
    +1 for above. Buy 11 inch rear shocks. They can be had relatively cheaply and make for a safer outcome. TC
  • BLK883
    BLK883
    How much for the 11" shockies? Thinking of going down that path
  • terroristone
    terroristone
    Get yourself a price from Ikon and im sure I can beat it, i'll also fit them for free.
    T1
