Online: Hilly, FONTANA302
2012 Wide Glide 103ci sounds rattly (tapping) in top end.. gets worse when hot..
  • tubbytuk2013
    tubbytuk2013
    Had the local Harley Dealer in Toowoomba change ALL Oils n Filters after i brought the bike 2nd hand from Harley Dealer in Brisbane. Not Serviced - just oils..
    Now it seems to Rattle (tap) in the top end.. and it gets worse when its hot..
    I put in a LED Temp/Oil Level meter (oil cap conversion) and before the LCD on the died it was sayng 110Deg C when hot.. and the dip stick shows oil about 3/4 the way up to MAX mark when hot/warm.
    Any Ideas ?
    HD Dealers in Toowoomba say its normal for a 103ci Dyna..
    This is my first Harley .. so i could use other people's advise please.
    Cheers.
    Tony.
  • tubbytuk2013
    tubbytuk2013
    Apart from the Stage 1 airfilter, V&H Big Radius Pipes and Screaming Eagles Pro Tune its Engine is Stock.
  • robots
    robots
    Hi,
    Yeah buy castrol GTT20W-50 or whatever weight as specified for lowest temperature where you live, there a table in the manual i think that tells you the weight
    Thanks
    Robots
    Yep....damn Synth oil turned my Evo into a rattle can. Back on the harley Dino oil now and she is getting better.
  • tubbytuk2013
    tubbytuk2013
    Thanks All,
    I am going to convert back to a mineral Oil (dino oil..lol)... this weekend..
    Is the Harley Mineral Oil and worse or better then say Mobil etc ...
    Cheers.
    Tony.
  • Ando
    Ando
    oil aint ya problem, 20w 50 syn or mineral its still the same weight
    whats heaver a tonne of bricks or a tonne of feathers
    hilly has already suggested the "C" lifters are crap so a decent set of lifters and some good adjustable pushrods and adjust accordingly is were I would start, might aswell do cams and inner bearings at the same time
    +1...I would be inspecting the lifters as well.
    I have a new noise on the Evo so its coming apart this weekend so i can inspect the lifters and primary side of things (just as well I buy gaskets by the 10 pack!)
    -1 on the oil...On the older Evos the new Synth Oil a no go, whereas on your new twink the Synth will be fine. Bloody expensive, but fine.
  • Ando
    Ando
    Not sure about expensive
    Penrite 10tenths 20W60,,,,,,,,,$215 FOR 20Litres at auto 1,,,,,$10.75/ liter and $43 per 4 liter
  • tubbytuk2013
    tubbytuk2013
    The bike only has 23,000km's.. is it normal for lifters to go so quick ?
  • Ando
    Ando
    seen them C Lifters fail with only a coupla thousand K's on them
