Front end clunk - 2008 FatBob
  • jmac
    jmac
    Hoping someone else has had this and solved it. I get a noticible 'clunk' from the front - not sure where - when I ride over driveway lip etc. Next doors cat seems fine so I figure something is loose. Checked and torqued every accessible bolt and nut from the seat to the fender including forks and head assembly. No joy. Doesn't happen under hard brakes.
    Is there any hidden gear / sensor etc in the tank or the instrument panel assembly that might be loose? Just one of those annoying little things that bug the shit out of you. Like the cat.
    Thanks for an great forum.
    Headstem bearings ? Know you said head assembly.
  • 06 Softail
    06 Softail
    Yep, I had same thing with mine, especially if you hit a pothole or cross railway tracks. Mine weren't Notchy,  just that noticeable feeling that there was some slight bearing movement, even though they had been adjusted up. Had mine replaced back in March this year, no problems since.
  • Daggs
    Daggs
    Tank bolts themselves not loose?
    Just tighten the head stem up a little and that clears it up.... However in the end it easier to just replace the bearings and races
  • jmac
    jmac
    Headstem doesn't seem to have any movement and the tank bolts are tight. For the cost of bearings I'll nip them up a bit more and then replace them if that doesn't work. Thanks for the quick replies.
  • robots
    robots
    Hi,
    What about fuel tank cap rattling? Yeah interesting
    or you got flush mount?
    Thanks
    Robots
  • beaglebasher
    beaglebasher
    i sometimes hear a clunk from under my arse / rear wheel area when i hit a pothole (2002 fatboy) and have looked for something loose and cant find anything. if i hit 100 potholes it might happen 3 times. fukin weired if you ask me. when it happens its an unmistakable clunk so i know i am not imagining it. any ideas on that one?
    Small crack in the wheel can make nice clunks when going over things.
  • motor_head
    motor_head
    Also check for cracked axle retainer (bottom of fork legs) and loose brake caliper.
    If the bike is an import , they have a notorious reputation for doing headstem bearings due to pressure washing before shipping . (Squirting the fuck out of the bearings and getting water in there , in no time they seize and rust up .) Have you jacked the bike up with the front in the air to perform test ?
  • jmac
    jmac
    Yep calipers and fork leg caps all tight. Can see myself pulling the headstem apart I guess. Thanks for the ideas.
    Have you just fitted a fork brace at all? I got a clunk when i fitted one.
  • jmac
    jmac
    Yea tank bolts good. No fork brace and the clamps are tight. fork end caps are good and the bolts tight.
  • Daggs
    Daggs
    Head stem then I guess !!
    Just a long shot, but my brake pads gave a clunk on a different bike i had from time to time. Rock bike back and forth with front brake on and see If there is any play in them.
