Online: Hilly, FONTANA302
2011 Wide Glide Electrical
  • Lukes926
    Lukes926
    I think I know the answer but here goes........I changed the bars over on my 2011 wide glide to some fat T-Bars. I ran the cables through internally and hooked everything back up.
    When I turn the ignition on I get the fuel guage, the pump is working in the tank, the headlight is on. But........... The indicators, dash lights and tacho will not work.
    I know a multi meter is the answer, has anyone else had this problem. Is it a pinched cable? or somthing else? Fuses seem in tact.
    what you said , ,plug not pushed all the way in
  • Sparra
    Sparra
    I just recently had a similar problem when I put my apes back on and it was a fuse blown...
