2014 exhaust options
  • ConR
    ConR
    So it seems at this point in time, I have two options for 2014 models:  VH Shorties, or Samson Shorties.  Not much of a choice haha.  Apart from slip-ons, which I don't want to do.
    Everything else seems to be months off.
    Anyone know of any other pipes that fit the 2014 models?  I'm on the hunt for a 2-1, but nothing there.  The Bobcat, RSD Tracker and Slant, Freedom American Outlaw....none fit.
  • 883n Harley Convert
    883n Harley Convert
    What's changed??
  • ConR
    ConR
    Not entirely sure, but every manufacturer out there is saying their current pipes that fit 2013s don't fit 2014s.
  • ConR
    ConR
    OK, so update from the dealer. The reason no 2013 or earlier pipes fit is due to the introduction of ABS brakes as standard on all sporties. As a result, all the mounting points have changed, and the pipes no longer fit.
    Argh! Damn you Harley! One change ruins everything! Haha.
  • ConR
    ConR
    Correction. New 12mm oxygen sensor has been added, forcing a new mounting panel design for the 2014s.
  • terroristone
    terroristone
    ConR beat me to it. You might find that most pipes will fit using oxy sensor adaptor plugs.
    T1
  • terroristone
    terroristone
    I spoke to somebody about exhaust options for the 2014's and have confirmed that the pipes will be different. Reasons are :
    Oxy sensors
    ABS  fitted to bikes
    The ABS will be in the way and different bracket will be needed, pipes will also be differernt ( sit out a little more for clearance apparently)
    Also the front rotors are larger....along with a heap of other little differances.
    Regards - T1
  • ConR
    ConR
    Yeah I echo that. Have spoken to every company I can think of that makes pipes. Samson, VH, Freedom, Bassani, Supertrapp. Apart from slip-ons, VH is the ONLY company that makes a set that works on the 2014s, and even then, only the short shots model works. Nothing else.
    Everyone else is a couple months off releasing anything still.
  • Rocky2010
    Rocky2010
    Harley stayed very static for a long time whith their bikes which made it easy for aftermarket manafacturers to make parts for Harley motorcycles.
    But over the last few years there seems to be a trend to change things more often with newer models.
    Probably a market ploy by Harley to upset the aftermarket guys, in turn owners will purchase more Genuine Harley parts. Just my view on the matter.
  • fizball
    fizball
    Also there ads say a "new closed loop exhaust system". WTF does that mean? Weren't they always?
  • terroristone
    terroristone
    High speed Wide band oxy sensors 12mm fittings!
  • ConR
    ConR
    According to Samson, they're exhausts fit the new 2014 models. They emailed me back. I find that a bit odd, unless they've reworked them all to fit.
    For eg, their website says the Legend Sweepers fit 2004-2014 models. How can that be?
