Lyndall Gold Pads
  • Maxiboy
    Maxiboy
    I've been moaning about the crap brakes on my Deluxe for a while now and under recommendation from some forum members I went out and spent $70 dollars on some Lydall Gold Pads. Installed them on the weekend and went for a good long ride to bed them in. They are worth every cent! There is a real noticable difference in the stopping power and I don't have to squeeze the shit out of my lever to stop anymore. Feel is progressive and around town it's an easy 2 finger action to stop. The more I rode the better they felt, they are a Carbon-Kevlar composition, well pakaged and went sraight on with no fuss. Highly recommended!
  • blueystar
    blueystar
    So which shop do I go to for these
  • mickle
    mickle
    +1 with the Lyndall pads, you can get them from Rollies blueystar.
  • ozymax
    ozymax
    and not only do they stop they don't put brake pad dust all over your nice pretty wheels.
    Been using them for years and always to put them on any of the mates bikes I work on, they just plain work great
  • TJU
    TJU
    Hey Ozy , do you get yours through Rollies or someone else ... I have a 6 piston PM calliper on a 13" rotor ... is there any special spec pad I should look at and what do you think is to dear a price .
    Tim .
  • ozymax
    ozymax
    Tim yes Rollies shipping on pads would be high I think due to weight, As far as I know he is the only supplier in Bris, From memory they are about $70 or $80 per set. Not sure if they do them for 6 spots or not as have never looked but they would be more maybe $100 or so, Gold plus is what I use
  • ozymax
    ozymax
    Tim here ya go
    http://www.lyndallbrakes.com/performance-machine/
    remember price is in USA. use the HD pricing to see how much extra from rollies and work the % to yours and it will give you an idea
  • TJU
    TJU
    Cool thanks Ozy .
  • Rocky2010
    Rocky2010
    Also a thing to note is the standard harley rotor, I have always had the shits with Harley crap brakes no feel so they feel very wooden. I dont know why HD dont put dual disks on the front as the weight of the bike is one contributing factor to sub standard braking.
    I have changed the standard rotors front and rear on my 2010 Fatboy Lo to the HD floating rotors and they really transform the brakes into a braking system with more feel and better response overall much better braking. I have changed the pads on the front to EBC and the standard HD pads on the rear. Overall the brakes perform so much better. New Rotors were the best contributing factor to the better braking.
    Dual disks would be so much better. HD should put the front brakes from the Tourers onto the rest of the range. Not a fan of the saying I dont want dual disks as I cant see the wheel. Stuff the wheel I would rather have better braking. I want brakes to work like they did on my Japanese and Italian bikes but that isnt going to happen on an anitquated Harley
  • blueystar
    blueystar
    So why did you buy a harley
  • 45WL
    45WL
    yesyes for these, have them front and rear - really improvement
    Also upgraded the stock brake lines to braided SS from HEL performance
    Should be a standard "upgrade" from the showroom
  • Captain Hook
    Captain Hook
    Harley spokes are not chromed, they look like chrome but are nickel plated, rims are chromed.
    + 1 for dual disc's
  • 45WL
    45WL
    Didnt have any fpor my 2011 FXDWG but I sent them my originals and they made duplicates up - quick turn around, great product
