Boom Box Navigation System
  • mikl
    mikl
    I recently bought an FLHX 2014 strret glide and had the 6.5" Boom box Sat Nav Fitted.
    It appears that currently it does not suport bluetooth headsets only wired ones for comms.
    What this means is you can have a phone connected and displayed on the screen, however you cannot answer this in your bluetooth headset. Not very integrated.
    Does anyone know if this is going to be resolved by a Software update?
    Mine was also delivered without the corect maps - apparently I can do well in the UK but not Australia. This requires the entire system to be replaced at some poont in the future.
    Anyone know anyone involved in this within Harley that might enligten me on the further development of both bluetooth headset integreation and the addition of feature to the navigation system?
  • Hoppoz
    Hoppoz
    Have you resolved this issue? I'm looking at the same upgrade
