Online: snoozy
I learnt something tonight
    Hi ther forum buddies, Well as some of you know i have been playing with Tiggers pipes,  and upon removing active exhaust flapper drive unit from under the abs system, i wondered about just taping up the plug. But i found out that behind the unit once it is removed, there is a recepticle moulded into the side of the battery box that fits the AEV plug. So there you go folks. If you remove the AEV unit from the bike entirely ( not just the cable off the flapper), you can insert the plug into the purpose built recepticle.
    AND make sure you check your tyres for nails/screws etc before you go for a ride. When i was looking under the beasty, i found a small screw in the rear tyre. Bit of a bugger if i was out in the sticks and it went flat. Always good practice to check before each ride anyways........See ya's. Hutch-a-Pitchu.
  • Ted
    Ted
    Whats the best way to remove the entire aev unit ? do i need to get battery box or anything out of the way .. or do i come from the other side ?
  • beaglebasher
    beaglebasher
    what is an AEV unit?
  • beaglebasher
    beaglebasher
    I will ask that question again.
    What is an AEV?
    Active Exhaust Valve. You know the flapper thing in the pipe..
    On the tourers it unbolts from under the right hand side plastic side cover.
