Online: Hilly, FONTANA302
Looking for someone with decent tig welding skills
  • 45WL
    45WL
    Hi Guys
    I'm looking for someone around the Brisbane area that is reliable and has decent tig welding skills to manufacture a few bits me - any recommendations???
  • ozymax
    ozymax
    what side of town?
    depending on what it is a lot of shops tig weld. exhaust shops are ever where, take the bits in and just ask them to weld it up.
    Do what i did....buy your own machine and teach yourself to tIG. Its not hard and you will find that you use it way more than you thought you would.
  • 45WL
    45WL
    Ozymax: out west or up north preferably but I dont mind travelling for a decent job. was hoping the guy could do the fab and weleding but I can also do the fab - never thought of that
    Tussack: mate I'm ALWAYS game for some new tools and I have considered this but the $2000 outlay before I can start practicing is too rich for me..... or is it??? Seriously how long did it take you "get it right". Did you have previous welding experience before you picked up the tig torch?
  • Daggs
    Daggs
    Whoa $2000? Shop around mate, the worst thing is renting the bottles if you use the rig bugger all
  • Daggs
    Daggs
    Tig is pretty easy but a basic tig course at TAFE or your states equivalent wouldn't hurt, I've been doing it for over 30 years and it's great on stainless and alloy
  • 45WL
    45WL
    Daggs
    200 Amp ACDC invertor Tokentools/ Everlast/ Weldsmart/ Unimig = +/- $1500 even more if you go to CIG Weld, and even more on top of that to go to a Miller
    Helment, gloves, filler rods, tungsten, trolley etc = another $250 - $500
    As I said $2000 - cant justify it!!..... Well at least not yet ?????
    There is a mob in NSW that can sell you a full bottle (0.6m3) for $220, each refill after that is $70 including postage - which is a real option if you just stuff around everynow and again in the shed
  • Daggs
    Daggs
    Not sure where your getting your prices but you can get inverter tig machines for under $500 even cig weld have a 170 amp model available for under $500 with regulator and leads included.
    Anyway good luck !
    $600 for an inverter AC/DC 200 amp unit on eBay.
    $50 for the Ron Covell DVD on TIG basics
    Then some scrape steel and a few hours of time. TIG welding is very easy to learn!
  • 45WL
    45WL
    Thanks Guys for the reponses
  • 06 Softail
    06 Softail
    If you have ever tried welding using an Oxy set, well the basic technique is the same, but you are using an arc to heat the parent material instead.  I taught myself to tig weld when I was doing my apprenticeship, and that was welding Aluminium at that, I'd never welded Ally whether it be Mig or Tig before then.  Steel is more forgiving than Aluminium too.  Just remember not to touch the tungsten electrode with the filler wire, as it makes a bit of a mess, and then you will have to re-sharpen the electrode on a pedestal grinder.
    Keep practising, you will pick it up in no time.  I prefer tig welding, much cleaner, and when you get really good, the welds look bloody awesome, and no need for grinding them if you wish.
