Online: John.R, Stuart
Intiminators.
  • Hooters
    Hooters
    Just ordered some intiminators for my 48 and they recomend using a single rate spring.
    Can I just use the stock spring or should I order some springs from Race Tech?.
    Also looking at doing the air shock conversion at the rear.
  • terroristone
    terroristone
    you can use the stock springs. I prefer using ikons progressive springs with them.
    T1
  • Hooters
    Hooters
    Cheers.
  • Hooters
    Hooters
    Got all the gear together to do my front end. Wondering if anyone can point me in the direction of a good workshop or mechanic to do the instal. Would love to have a go myself but I don't really have anywhere to do it. Any recommendations would be appreciated.
  • terroristone
    terroristone
    Where are you located? I have done many of these front ends. I'm located in Melbourne's West, i'm available on weekends also.
    Regards - T1
    AA Custom Cycles
  • Hooters
    Hooters
    Thanks for the reply.
    I'm in the eastern burbs of melbourne. Let me know when the best time to ring is and ill give you a call.
  • terroristone
    terroristone
    Calls I can take after hours, txt any time!
    T1
  • Hooters
    Hooters
    Sweet.
    Like the new avatar by the way.
