Online: Hilly, speedzter
Fatbob fender
  • ryno_0000
    ryno_0000
    G'Day all,
    I'm looking at getting a 1200 custom, does anyone know if a fatbob style fender has been made for these? I have seen the bobtail style but not the straight fatbob style. I tried searching but have yet to find any info on this subject.
    Ryno
  • ryno_0000
    ryno_0000
    The fat bob fender seems straighter than the softail fender, it only has a slight lip at the rear. Just wondering if anyone makes one, or if I will have to make a fiberglass one myself.
  • 98superglide
    98superglide
    I would like to find on too...I think 7 metal west in the states could do one for you, google them...
  • ryno_0000
    ryno_0000
    Just emailed 7 metal west, will let you know how I go.
  • 98superglide
    98superglide
    They have great gear, and I'm told the quality is the best there is...
  • ryno_0000
    ryno_0000
    I have another question about a 1200C, What is the pro's and con's of the 21inch front wheel. I rate the look of it, just like wide glides. I have heard they will follow cracks on the road but I just dont know enough about them to make a call on weather I want one on looks alone. Any help?
  • GT 1200
    GT 1200
    What year? is this a new bike that you want to change or does it already have a narrow tyre? just asking as mine has the fat 16" tyre.
  • ryno_0000
    ryno_0000
    The bike has a narrow tyre standard, I just dont know the pros and cons with tyre /wheel types.
  • ryno_0000
    ryno_0000
    Cheers for the advice mate, yeah I think i will stick with the larger wheel.
