Axtell Oil Bypass
  • Ando
    Ando
    Fitted the Bypass to the Softy and made an oil pressure gauge up outa some fittings to see what its doing to the oil pressure
    well it has a Hot idle of 22psi and seams to hover around 45 t0 50psi out on the road at high rpm or low rpm
    This the bodged up gauge
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_002550_zps94f20e2d.jpg.html][/URL]
    This Hot Idle
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_002560_zpsfa1a7bfa.jpg.html][/URL]
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_002556_zpsd492286e.jpg.html][/URL]
    And this is cruising around the streets
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_002554_zps95f7725c.jpg.html][/URL]
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_002552_zps92230f28.jpg.html][/URL]
    Is this a good thing ??????
  • ozymax
    ozymax
    it better be
  • HogBag
    HogBag
    I have oil pressure and temp gauges on my bagger and there worth the money to know what the engine is doing through the summer months.
  • HogBag
    HogBag
    perfect for a tc evos have less around 13 psi  idle  35 psi  on revs hot
    some times even lower on relly hot days/traffic
    if your worried ando look up ert products they make up hotrod kits for harley oil pumps and have some good info on there site
    sounds like a lot of pressure for roller bearings Ando?
    What oil pump are you running ?
    Pretty close to the newer SE high volume oil pumps, maybe a bit higher.
    Do you know what the pressure was before ?
    depends on oil grade & temp  cold or hot
